Cyclone10LP SEU CRC error implementation (part 2)
Dear support team,
I open a new post as the first has been closed without an answer, only references to already read documentation .
We have enabled the CRC_ERROR pin and we want to instantiate the block cyclone10lp_crcblock in order to retrieve the CRC calculated during configuration.
The cyclone10lp_crcblock is instantiated in a dedicated IP (attached with this message) where the CRC is output after 10s during 32 clocks.
When observed with signaltap there is no data output from the cyclone10lp_crcblock, could you help us to solve this issue ?
Below is the VHDL code used to output the CRC code :
//----- Instantiation and configuration -------------------------------------------------------
uut_cyclone10lp_crcblock : cyclone10lp_crcblock
generic map
oscillator_divider => 8 ,
lpm_type => "cyclone10lp_crcblock"
Port map
clk => s_clk_crcblock ,
shiftnld => s_shiftnld ,
ldsrc=> s_ldsrc ,
crcerror => s_crcerror ,
regout => s_regout
s_shiftnld <= '0';
s_ldsrc <= '0';
s_clk_crcblock <= i_clk when s_output_crc='1' else '0';
o_regout <= s_regout;
o_error_pin <= s_crcerror;
//----- Process to output data -------------------------------------------------------
pro_get_crc32: process(i_clk)
begin
if i_rst = '0' then
sv_cnt <= (others=>'0');
sv_crc32 <= (others=>'0');
s_output_crc <= '0';
elsif rising_edge(i_clk) then
-- Wait 10 s @ 60MHz then output register : 600000000
if unsigned(sv_cnt) = 600000000 then
s_output_crc <= '1';
sv_cnt <= std_logic_vector(unsigned(sv_cnt) + 1);
-- Stop after 32 clocks 600000032
elsif unsigned(sv_cnt) = 600000032 then
-- Stop counter 33 clocks 600000033
elsif unsigned(sv_cnt) = 600000033 then
-- Count after reset
else
end if;
if s_output_crc = '1' then
sv_crc32 <= sv_crc32(sv_crc32'length-2 downto 0) & s_regout;
end if;
end if;
end process;
GB
- Farabi_Altera
Can you try this VHDL?
i_cyclone10lp_crcblock : cyclone10lp_crcblock
generic map (
oscillator_divider => 1)
port map (
clk => '0',
shiftnld => '1',
crcerror => s_altcrc_crcerror,
regout => open);
regards,
Farabi
- UF1
Farabi,
It doesn't work out.
The IP cyclone10lp_crcblock isn't instantiated in Quartus whereas it is under modelsim.
The IP cyclone10lp_crcblock doesn't appear in the IP catalog (Quartus 22.1).
I have tried to include the following library :
library cyclone10lp;
use cyclone10lp.cyclone10lp_components.all;Any suggestion ?
GB
2.15.0.0
- UF1
Farabi,
First, thanks for your consideration. I'm using a protonmail address as the mail of the company I'm working for doesn't log in Intel website. If you send me an email I can reply to, i can forward you my company's mail.
Beside that, please read the topic, i have described the issue we are facing several times: we only want to read the CRC generated by the cyclone10lp_crcblock.
I have instantiated the IP described in the chapter SEU mitigation, with signaltap I capture the IP signals but no output is generated.
GB
2.15.0.0 - Farabi_Altera
Hello GB,
I have sent private email to ask your company email(currently you are using protonmail). Please reply so I can send meeting invitation to you.
regards,
Farabi
- Farabi_Altera
Hello GB,
I am sorry my answer does not answer your question.
To have a better communication, can we have a call?
I will send meeting invite to your email.
regards,
Farabi
- UF1
Farabi,
It doesn't answer to the initial question, the point is to instantiate the primitive cyclone10lp_crcblock of a Cyclone10LP device in order to get the calculated CRC32 of the RAM. The link corresponds to a custom CRC implementation on a Nios.
This issue has been opened from 3 months and has been published over 2 different posts because your quality procedure close a ticket even when no answer is provided.
Please make your organization aware that the customer quality has really decreased compared with the original Altera company. At that time, even a small company had a direct contact with a support engineer from Altera or a distributor. Now, everything is tracked but there is no more answer. As a reminder, we are not asking for a very specific rocket-science question but only how to use a feature of your device.
You and your colleagues are not responsible of this blocking point only is your organization because of political choices.
GB
Do you have further request?
regards,
Farabi
- Farabi_Altera
I am sorry for late reply. For ref design, can you access this link ?
CRC ref design link C10LP : https://www.intel.com/content/www/us/en/design-example/714548/intel-cyclone-10-lp-fpga-nios-ii-processor-custom-instruction-for-intel-cyclone-10-fpga-design-example.html
I can forward the design to you if you dont have access to this link.
regards,
Farabi
- UF1
Farabi,
Do you have an example project implementing the CRC read feature we can start with ?
GB
Is your design following this guide? link : https://www.intel.com/content/www/us/en/docs/programmable/683777/current/accessing-error-detection-block-through.html
Can you share .qar file so we can try at our setup.
regards,
Farabi
- UF1
Hello Farabi,
I can't share you the whole project but attached is the VHDL file of IP instantiated at the top. I use signaltap to visualize the output of the of cyclone10lp_crcblock.
Yes, I followed this guide and read the documentation of the handbook (ID 683777) chapter 7 "Seu mitigation in Intel Cyclone10 LP Devices". We use the device Cyclone 10 LP 10CL120YF484I7G.
Thanks for your support,
GB
2.15.0.0
- Farabi_Altera
This is to let you know I have been assigned to this case.
I am checking your request and get back to you as soon as possible.
regards,
Farabi
