Shoval's avatar
Shoval
2 years ago
Cyclone V SoC GSRD precompiled SD boot failure
Hello all,
I have recently tried to execute the GSRD on the Cyclone V SoC (https://www.rocketboards.org/foswiki/Documentation/CycloneVSoCGSRD) , the first step is to boot a precompiled SD image.
I have downloaded the https://releases.rocketboards.org/2022.11/gsrd/c5_gsrd/sdimage.tar.gz and flashed an SD card as explained in the Windows chapter.
I than tried to boot the board.
Seems like the load of the FPGA is failed in u-boot with the following error message: "Command 'load' failed: Error -6"
The u-boot then exists, kernel is starting and at some point the board resets and the boot sequence re-initiated.
I then removed the FPGA load lines in u-boot.scr, stopped manually in u-boot, flashed the FPGA via JTAG and continued to the kernel boot, It was successful and I had a running Linux prompt with a loaded FPGA.
when running the u-boot commands to load the FPGA:
load mmc 0:1 ${loadaddr} soc_system.rbf;
fpga load 0 ${loadaddr} $filesize;
the error messege "Command 'load' failed: Error -6" appears, even with other rbf files.
Since this is the precompiled SD image from Intel it seems like something is very strange
Also, in other SD images the FPGA load from u-boot was successful so I assume its not a board issue.
Has anyone experienced such issues?
  • Hello Aik,
    After checking the pin configurations you provided - nothing actually booted --> No UART prints on putty of any kind.
    Setting the following:
    J26: Short pins 1-2
    J27: Short pins 2-3
    J28: Short pins 1-2
    J29: Short pins 2-3
    J30: Short pins 1-2
    And the rest as you instructed:
    J5: Open
    J6: Short
    J7: Short
    J9: Open
    J13: Short
    J16: Open
    SW1: All OFF
    SW2: All OFF (modified)
    SW3: ON-OFF-ON-OFF-ON-ON (modified)
    SW4: OFF-OFF-ON-ON (modified)
    I was able to successfully boot and load FPGA from u-boot.
  • aikeu's avatar
    aikeu
    Hi Shoval,
    I am closing the thread for now.
    Aik Eu
  • aikeu's avatar
    aikeu
    Hi Shoval,
    I will close the thread if there is no further question.
    Aik Eu
  • aikeu's avatar
    aikeu
    Hi Shoval,
    Sorry that I do not undertand your respond. No UART logs after following the MSEL and SW settings?
    However you were able to successfully boot and load FPGA from u-boot?
    Aik Eu
    • Shoval's avatar
      Shoval
      Hi Aik,
      J26: Short pins 2-3
      J27: Short pins 2-3
      J28: Short pins 2-3
      J29: Short pins 2-3
      J30: Short pins 2-3
      Results in no load at all, not FPGA load and not u-boot/Linux boot, what I meant is that powering up the board using those configuration results in empty Putty with no prints at all.
      The configuration that works for me - successfully boot and FPGA load is the following:
      J26: Short pins 1-2
      J27: Short pins 2-3
      J28: Short pins 1-2
      J29: Short pins 2-3
      J30: Short pins 1-2
      J5: Open
      J6: Short
      J7: Short
      J9: Open
      J13: Short
      J16: Open
      SW1: All OFF
      SW2: All OFF
      SW4: OFF-OFF-ON-ON
  • aikeu's avatar
    aikeu
    Hi Shoval,
    Can double check the bleow SW or MSEL jumpers settings are correct on the board?
    First, the board jumpers need to be configured as follows:
    J5: Open
    J6: Short
    J7: Short
    J9: Open
    J13: Short
    J16: Open
    J26: Short pins 2-3
    J27: Short pins 2-3
    J28: Short pins 2-3
    J29: Short pins 2-3
    J30: Short pins 2-3
    J31: Short
    Then, the board switches need to be configured as follows:
    SW1: All OFF
    SW2: All OFF
    SW4: OFF-OFF-ON-ON
    Aik Eu
    • Shoval's avatar
      Shoval
      Hello Aik,
      J26: Short pins 1-2
      J27: Short pins 2-3
      J28: Short pins 1-2
      J29: Short pins 2-3
      J30: Short pins 1-2
      J5: Open
      J6: Short
      J7: Short
      J9: Open
      J13: Short
      J16: Open
      SW1: All OFF
