Cyclone V SoC GSRD precompiled SD boot failure
- 2 years ago
Hello Aik,
After checking the pin configurations you provided - nothing actually booted --> No UART prints on putty of any kind.
Setting the following:
J26: Short pins 1-2
J27: Short pins 2-3
J28: Short pins 1-2
J29: Short pins 2-3
J30: Short pins 1-2And the rest as you instructed:
J5: Open
J6: Short
J7: Short
J9: Open
J13: Short
J16: OpenSW1: All OFF
SW2: All OFF (modified)
SW3: ON-OFF-ON-OFF-ON-ON (modified)
SW4: OFF-OFF-ON-ON (modified)I was able to successfully boot and load FPGA from u-boot.
Hi Shoval,
Sorry that I do not undertand your respond. No UART logs after following the MSEL and SW settings?
However you were able to successfully boot and load FPGA from u-boot?
Aik Eu
Hi Aik,
J26: Short pins 2-3
J27: Short pins 2-3
J28: Short pins 2-3
J29: Short pins 2-3
J30: Short pins 2-3
Results in no load at all, not FPGA load and not u-boot/Linux boot, what I meant is that powering up the board using those configuration results in empty Putty with no prints at all.
The configuration that works for me - successfully boot and FPGA load is the following:
J26: Short pins 1-2
J27: Short pins 2-3
J28: Short pins 1-2
J29: Short pins 2-3
J30: Short pins 1-2
J5: Open
J6: Short
J7: Short
J9: Open
J13: Short
J16: Open
SW1: All OFF
SW2: All OFF
SW4: OFF-OFF-ON-ON
