BrianSune_Froum's avatar
BrianSune_Froum
1 year ago
Cyclone V SoC custom board preloader boot sdram test issue
Dear Intel FAE and ALL,
This is Brian and having issue on maximum 2GB DDR3 boot sanity test.
There is a warning like these:
"SDRAM: Running EMIF Diagnostic Test ...Iteration 1734:, expect 0x20a69210 from address 0x20a69213, read 0x20a69210 insteadFailed"
But w/o the SDRAM test on preloader, the system can boot into distro and passed memtester.
Do the preloader have any bug on the memory size of the SDRAM?
It do show a 2048M size message.
memtester log:
brian@brian:~$ sudo memtester 1900M
memtester version 4.3.0 (32-bit)
Copyright (C) 2001-2012 Charles Cazabon.
Licensed under the GNU General Public License version 2 (only).
pagesize is 4096
pagesizemask is 0xfffff000
want 1900MB (1992294400 bytes)
got 1900MB (1992294400 bytes), trying mlock ...locked.
Loop 1:
Stuck Address : ok
Random Value : ok
Compare XOR : ok
Compare SUB : ok
Compare MUL : ok
Compare DIV : ok
Compare OR : ok
Compare AND : ok
Sequential Increment: ok
Solid Bits : ok
Block Sequential : ok
Checkerboard : ok
Bit Spread : ok
Bit Flip : ok
Walking Ones : ok
Walking Zeroes : ok
8-bit Writes : ok
16-bit Writes : ok
Loop 2:
Stuck Address : setting 3^C
  • tehjingy_Altera's avatar
    tehjingy_Altera
    Hi
    Jingyang, Teh
  • @JingyangTeh_Altera
    Allow me, based on my ultra lite knowledge on U-Boot and SPL.
    The DDR_SI test actually can be transferred from old U-Boot to latest mainstream Das U-Boot (Altera U-Boot).
    According to Siemens patches I do see s.t. very similar.
    This is just feature that Altera plan to do so or not.
    Apart from U-Boot version I cannot see such test is very complex compared to old 2013 trunk.
    Meanwhile, the U-Boot itself from mainstream already included calibration of SDRAM, but had not study deep on such test.
    tehjingy_Altera
    Hi
    Apologize for the late reply.
    For the new flow the SPL s no longer generated from the bsp-editor.
    The SPL version is tied together with the u-boot version.
    It is still separate from the uboot. ( https://github.com/altera-fpga/u-boot-socfpga/blob/socfpga_v2024.07/arch/arm/mach-socfpga/spl_gen5.c)
    In the latest spl code, there is no longer sdram diagnostic test.
    New flow:
    https://altera-fpga.github.io/rel-25.1.1/embedded-designs/cyclone-v/sx/soc/boot-examples/ug-linux-boot-cve-soc/#the-new-flow
    Jingyang, Teh
    • BrianSune_Froum's avatar
      BrianSune_Froum
      @JingyangTeh_Altera
    The work stations are in Quartus 18.1.
    So the uboot is generated via make uboot from bsp-editor MakFile.
    Do you mean even the EDA is 18.1 the ARM development can still updated to latest?
    I am not too sure on uboot, as for the kernel it is using most latest 6.12.11 dirty.
    The DDR3 2GByte is fully tested on distro even ran the frame-buffer w/o any issue.
    This is why it is very puzzling why larger than 1GByte will have such issue.
    Opps,
    I think you had misunderstand the issue point correct me if I misunderstand.
    The issue is happened on "preloader" dram check not uboot phase?
    The check is ran via the spl.c on the sdram check function if I understood it right.
    tehjingy_Altera
    Hi
    Could you share what uboot version that you are using?
    There is no known issue for the recommended uboot version socfpga_v2024.07.
    Jingyang, Teh
