13 years ago
Cyclone V: PCIe x4 + XAUI.
Hello!
I have 5CSXFC6D6F31C6.
Can I use PCIe x4 and XAUI simultaneously?
    Basically, Native Phy is just a transceiver/Physical layer used in XAUI protocol.
    In order to fully compliance the XAUI protocol, you need to write a a soft logic such as deskew fifo to compensate the lane skews, rate matcher to compensate the ppm difference and other blocks that required by XAUI protocol.
    --- Quote Start ---
    Oops...I'm not aware of you are using megawizard XAUI soft IP.
    Unfortunately, you not able to use this option unless you build your own XAUI IP by using native phy ip.
    --- Quote End ---
    Thank you! Is there a guide, which describes how to set up a Native PHY in XAUI mode?
    --- Quote Start ---
    I'm not sure you are using which QII version.
    --- Quote End ---
    Sorry, I am using QII 13.0.0 Build 156.
    --- Quote Start ---
    In CV Native PHY GUI, you should enable the "Use external PLL" option if you want to use fPLL a transmit PLL feature.
    --- Quote End ---
    Unfortunately, there is no such option In "XAUI PHY v13.0" and "Cyclone V Hard IP for PCI Express v13.0" Megacore functions.
    --- Quote Start ---
    Cyclone V support FPLL as TX PLL feature.
    --- Quote End ---
    Yes, in the "Upcoming Cyclone V Device Features" it is written that
    "PMA clock output (fPLL as transmit PLL)" is currently supported.
    --- Quote Start ---
    Please check for the datasheet what is the MAX frequency the FPLL can support?
    --- Quote End ---
    Yes, fPLL Serial Data Range is from 0.611 Gbps to 3.125 Gbps.
    --- Quote Start ---
    Maybe you can use 1 of the FPLL to create 1.5625GHz Fast clock for XAUI? :p
    --- Quote End ---
    The most important question is how to make it? :)
    When I am generating XAUI Megacore function I can choose only CMU PLL type.
    --- Quote Start ---
    Hello!
    --- Quote End ---
    According to the handbook, I came to the conclusion that answer is no.
    Device has nine channels.
    PCIe x4 requires all ( 3 ) channels fron GXB_L0 ( Сh0 - Ch2 ) and 1 channel from GXB_L1 ( Ch3 ). Also, one channel ( Ch4 ) from GXB_L1 is needed as CMU PLL.
    XAUI requires all ( 3 ) channels from GXB_L2 ( Ch6 - Ch8 ), 1 channel from GXB_L1 ( Ch5 ). And also need channel for CMU PLL. But we have not left channels.
    Am I wrong?
