13 years agoCyclone V: PCIe x4 + XAUI.
Hello! I have 5CSXFC6D6F31C6. Can I use PCIe x4 and XAUI simultaneously?
13 years ago --- Quote Start --- Cyclone V support FPLL as TX PLL feature. --- Quote End --- Yes, in the "Upcoming Cyclone V Device Features" it is written that "PMA clock output (fPLL as transmit PLL)" is currently supported. --- Quote Start --- Please check for the datasheet what is the MAX frequency the FPLL can support? --- Quote End --- Yes, fPLL Serial Data Range is from 0.611 Gbps to 3.125 Gbps. --- Quote Start --- Maybe you can use 1 of the FPLL to create 1.5625GHz Fast clock for XAUI? :p --- Quote End --- The most important question is how to make it? :) When I am generating XAUI Megacore function I can choose only CMU PLL type.
