8 years agoCyclone V: How to generate a Trigger Signal ?
Can anyone suggest me, how to create trigger signal for controlling 128 bits counter data ?4 Replies
- SS5
I am trying to generate Trigger signals and Counter data through Quartus and NIOS.
Verilog code:
module Counter( input clk, input enable, input reset, output reg[31:0] Final_value // output wire trig ); reg[31:0] counter_out; reg [7:0] temp=0; reg [31:0] counter_result; wire temp1; wire temp2; reg trig; always@(posedge clk or negedge reset) begin if(~reset) begin trig<=0; temp<=0; counter_out<=0; end else if (enable==1'b1) begin counter_out<=counter_out+1; temp<=temp+1; if(temp==25) begin temp<=0; trig<=~trig; end end assign temp1=trig; assign temp2=temp1&&clk; always@(posedge temp2 or negedge reset) if(~reset) counter_result<=0; else begin counter_result<=counter_result+1; end always@(posedge trig or negedge reset) if(~reset) Final_value<=0; else begin Final_value<=counter_result; end endmodulemodule Counter( input clk, input enable, input reset, output reg[31:0] Final_value // output wire trig ); reg[31:0] counter_out; reg [7:0] temp=0; reg [31:0] counter_result; wire temp1; wire temp2; reg trig; always@(posedge clk or negedge reset) begin if(~reset) begin trig<=0; temp<=0; counter_out<=0; end else if (enable==1'b1) begin counter_out<=counter_out+1; temp<=temp+1; if(temp==25) begin temp<=0; trig<=~trig; end end assign temp1=trig; assign temp2=temp1&&clk; always@(posedge temp2 or negedge reset) if(~reset) counter_result<=0; else begin counter_result<=counter_result+1; end always@(posedge trig or negedge reset) if(~reset) Final_value<=0; else begin Final_value<=counter_result; end endmoduleEnable signal is coming from NIOS through PIO. After receiving the enable bit, code should generate Trigger signal, and at every neck edge (either positive or negative) i need to store the counter data in register.
For above process, i have used AVALON FIFO core, but in NIOS console i am not getting proper counter data. Please suggest me
You can use on chip memory as register. use one of the memory address like register and assign a bit to trigger the counter in a c-code in eclipse design. This bit to be used in you HDL coding to trigger counter. (embedded code<->Nios<->On-chip memory<->user logic) Look into below link you may get some idea. http://scale.engin.brown.edu/classes/en2911xf14/qsys_comp.pdf Let me know if you need any further assistance. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) - Altera_Forum
--- Quote Start --- Hi, What you want to control with counter? Enable can also be used as trigger. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) --- Quote End --- Actually what i am trying to do :( Sending LVDS signal [128 bits counter data] from cyclone V to XILINX Custom Board, and trying to control LVDS signal through trigger in NIOS Processor. I worked in XILINX but i am new to Altera and Qsys. So please help me in this part. I need to try the LVDS signal through trigger via NIOS Processor. How ? ? - Altera_Forum
