8 years agoCyclone V: How to generate a Trigger Signal ?
Hi, Can anyone suggest me, how to create trigger signal for controlling 128 bits counter data ?
8 years agoHi,
You can use on chip memory as register. use one of the memory address like register and assign a bit to trigger the counter in a c-code in eclipse design. This bit to be used in you HDL coding to trigger counter. (embedded code<->Nios<->On-chip memory<->user logic) Look into below link you may get some idea. http://scale.engin.brown.edu/classes/en2911xf14/qsys_comp.pdf Let me know if you need any further assistance. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
