8 years agoCyclone V: How to generate a Trigger Signal ?
Hi, Can anyone suggest me, how to create trigger signal for controlling 128 bits counter data ?
SS5
8 years agoHello,
I am trying to generate Trigger signals and Counter data through Quartus and NIOS.
Verilog code:
module Counter(
input clk,
input enable,
input reset,
output reg[31:0] Final_value
// output wire trig
reg[31:0] counter_out;
reg [7:0] temp=0;
reg [31:0] counter_result;
wire temp1;
wire temp2;
reg trig;
always@(posedge clk or negedge reset)
begin
if(~reset)
begin
trig<=0;
temp<=0;
counter_out<=0;
end
else if (enable==1'b1)
begin
counter_out<=counter_out+1;
temp<=temp+1;
if(temp==25)
begin
temp<=0;
trig<=~trig;
end
end
assign temp1=trig;
assign temp2=temp1&&clk;
always@(posedge temp2 or negedge reset)
if(~reset)
counter_result<=0;
else
begin
counter_result<=counter_result+1;
end
always@(posedge trig or negedge reset)
if(~reset)
Final_value<=0;
else
begin
Final_value<=counter_result;
end
endmodulemodule Counter(
input clk,
input enable,
input reset,
// output wire trig
reg [7:0] temp=0;
wire temp1;
wire temp2;
reg trig;
begin
if(~reset)
begin
trig<=0;
temp<=0;
counter_out<=0;
end
begin
temp<=temp+1;
if(temp==25)
begin
temp<=0;
trig<=~trig;
end
end
assign temp1=trig;
if(~reset)
counter_result<=0;
else
begin
end
if(~reset)
Final_value<=0;
else
begin
end
endmoduleEnable signal is coming from NIOS through PIO. After receiving the enable bit, code should generate Trigger signal, and at every neck edge (either positive or negative) i need to store the counter data in register.
For above process, i have used AVALON FIFO core, but in NIOS console i am not getting proper counter data. Please suggest me
