John_C
1 year agoCyclone V HMC IBIS Model
I cannot find the IBIS model for the Cyclone V HMC (Hard memory controller). I tried looking here https://www.intel.com/content/www/us/en/support/programmable/support-resources/board-layout/ibs-ibis-...
- 1 year ago
Hi John_C,
I think you should follow the IO standard that the IP is currently using to connect the memory component.
For example DDR3, the IO standard is SSTL-15. You can use SSTL15_<io>_<feature> or similar IBIS model.
Adzim
AdzimZM_Altera
1 year agoHi John_C,
Adzim
- John_C1 year ago
This is what I had ended up using. Thank you.
