Cyclone V Avalon MM DMA PCIe does not export MSI Control signals
The Cyclone V Avalon MM DMA PCIe IP was obsoleted. The MSIControl_o is not available in the Avalon-MM DMA IP PCIe endpoint, what you can do is probably build a module that uses only the MSIintfc_o signals and write to the TXs port when an interrupt condition occurs, and not having the multiple message capability provided by MSICcontrol_o.
Regards -SK
- Seadog5 years ago
SK,
Thanks for your response.
My workaround was to provide a shadow register where S/W can store a copy of the Message Control field from the MSI capability structure. Then I don't need the MSIControl_o signals.
But what concerns me now is your information that the Cyclone V Avalon -MM DMA PCIe endpoint is obsolete. The IP is available to instantiate in a Qsys block, which I did; and I instantiated the Qsys block in a top-level design, and did a build in Quartus, and produced .sof and .pof files for the completed build.
But you also seem to be saying that I can still use the Cyclone V Avalon-MM DMA PCIe endpoint, even though it is obsolete. And it seems that the obsolescence of the core is unrelated to the missing MSIControl_o signals, which I am guessing were missing before the core became obsolete?
Thanks and regards,
Seadog
