13 years agoCyclone V + Micron DDR3 + Uniphy + NiOS == always freezing
Dear All, I beg your support (and begging I meant serious :(),
after three consecutive weeks of having burned engineering time, I decided surrendering with that Cyclone V Dev board and to post a thread at this forum. tools used ide Quartus 12.1 64Bit, Qsys, NiOS Eclipse Indigo fpga 5CGXFC7D6F31C6NES (2x Hard-IP DDR, 2x Hard-IP PCIe)board Altera official Cyclone V GX Dev Kit Board (with PCIe edge connector) ddr ram Onboard DDR3 RAM. Micron MT41J128M16JT-125 (x2, i.e. 32Bit data, 256MByte) troubles System containing NiOS + Uniphy DDR3 Soft-IP + DDR3 RAM wouldnt work when being debugged AND/OR free-ran. flow
- Qsys generates w/o significant warnings (ODT is disabled, Quick Simulation, nothing spectacular).
- Quartus Analysis/Synthesis performs w/o significant warnings (e.g. synthesized-away nodes, pin stuck at lo/hi, etc... usual round of suspects).
- After Analysis/Synthesis, Qsys generated pin assignemt .tcl script can be executed w/o any warning.
- Fitter/Assembler perform w/o significant warnings (e.g. time limited .sof, ... ).
- Download works just fine.
- NiOSII Eclipse IDE BSP generation, MAKE, download and debug works correctly -- as long as only onchip SRAM is accessed.
- As soon as DDR3 memory is accessed, debugger suspends, "stepping" is being shown and debugger would never return, neither is pausable.
- Probed all major pins using a GHz scope. Such as LVDS Clk_in (125MHz), LVDS MEM Clk_out (350MHz), MEM_RSTn, etc.... Pins' levels seem conclusive. Clocks running, no stuck at reset.
- NiOS Debugging-view provided memory dump works on onchip SRAM only
- a.s.a. DDR3 RAM address range is specified in memory dump window, "stepping" and subsequent freeze haunts me again.
- NiOSII IDE - Source Code which proved to run as long as DDR3 (again) is not accessed
- QSYS connectivity map
- Quartus schematic (sorry for showing to you this vintage kind of block design, but I love having a schematic type of design file constituting the top level entity of my designs (I used to work with Max+PLUS II in former times, ahh... Flex10K FPGAs + MAX CPLDs, good old times, being reminiscent for a moment.... :rolleyes:)
I'm not familiar with your device or board, but the behavior described sounds like the controller is not accepting commands (leaving the Avalon "waitrequest" asserted indefinitely, and hanging your NIOS).
What is the state of the local_init_done, local_cal_success, local_cal_fail signals? - Altera_Forum
Dear Kai,
Even i'm using same board(Cyclone V GX) & facing the issue same as you, please let me know whether you got any fix or work around to it. only difference b/w you & me is , I'm using Quartus 14.0 ver. please kindly help me.. thanks & regards, Amar - Altera_Forum
Why not try running the External Memory Interface Toolkit (EMIF) and check the DDR3 margins?
Post#5 in this thread http://www.alteraforum.com/forum/showthread.php?t=43992 Has a DDR3 hard-memory-controller test for the BeMicro-CV board (read the readme.txt file in the DDR project folder). Cheers, Dave - Altera_Forum
There is a bug in the memory controller, so you need to manualy change some lines of a file generated with Qsys.
If you check in examples you got with the board in file: cycloneVGT_5cgtfd9ef35_fpga\examples\board_test_system\qts_ddr3\c5gt_ddr3.zip\c5gt_ddr3\c5gt_ddr3.v it says:/* !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! You manually have to fix the HMC issue. !! Open the uniphy top RTL(q_sys_fpga_sdram.v) !! then, find the line that contains... !! .mp_cmd_clk_1(1'b0), !! change this to !! .mp_cmd_clk_1(mp_cmd_clk_0_clk), .mp_cmd_clk_1 (mp_cmd_clk_0_clk), // (terminated) .mp_cmd_reset_n_1 (mp_cmd_reset_n_0_reset_n), // (terminated) .mp_cmd_clk_2 (mp_cmd_clk_0_clk), // (terminated) .mp_cmd_reset_n_2 (mp_cmd_reset_n_0_reset_n), // (terminated) .mp_cmd_clk_3 (mp_cmd_clk_0_clk), // (terminated) .mp_cmd_reset_n_3 (mp_cmd_reset_n_0_reset_n), // (terminated)
