8 years agoCyclone IV GX transceiver eval board ethernet issue
I am trying to implement ethernet protocol using Cyclone IV GX transceiver starter kit and I am running into few issues. I am not using the triple mac ip core. first thing, I was able to configure the 88e1111 chip to disable the auto negotiation and set the rate to 1Gbps. After this I was able to see the data from the PHY as BC 50 BC 50 .....which tells me the PHY is in idle state. It was sending auto negotiating pattern before I configured PHY. When I sent pin command to the board, I can see the Rx LED blinks as long as I send the ping command, but I don't see the data changing on the receiver. PHY still sends the same idle pattern even when I send the ping command. Am I missing something? Do I need to send some information to PHY from FPGA, so that it can initiate the bit transfer. It would be great, if someone can help me with this Thanks, Ramakrishna1 Reply
I was able to get the data through 88e1111 to fpga. I had to send the same data pattersn BC 50 BC 50 ......to the PHY to make sure fpga is not idle state. Once I did this, I was able to see the data packet from the computer in signaltap. Only thing was when I was sending BC 50 BC 50....pattern I had to make sure I made the tx_control high when I send out BC so that the transceiver knows to encode it as a control word as opposed to a data word
