8 years agoCyclone IV GX transceiver eval board ethernet issue
Hi, I am trying to implement ethernet protocol using Cyclone IV GX transceiver starter kit and I am running into few issues. I am not using the triple mac ip core. first thing, I was able to con...
8 years agoI was able to get the data through 88e1111 to fpga. I had to send the same data pattersn BC 50 BC 50 ......to the PHY to make sure fpga is not idle state. Once I did this, I was able to see the data packet from the computer in signaltap. Only thing was when I was sending BC 50 BC 50....pattern I had to make sure I made the tx_control high when I send out BC so that the transceiver knows to encode it as a control word as opposed to a data word
