11 years ago
Cyclone IV configuration - nCONFIG signal and JTAG programming issue
I have a custom board for EP4CE22E22 Cyclone IV FPGA. I have configured the board for JTAG only mode and using USB Blaster Rev.B for programming. The problem I am facing is that JTAG Scan fails with "JTAG chain Broken" error. The signal levels are are follows:
AT POWER UP:
nSTATUS -> HIGH (A0 on attached figure)
nCONFIG -> LOW (Screen shot from logic analyzer shows that nConfig (A1 on figure) goes low after 4ms but this duration is random and sometimes it stays high for several ms)
TCK -> LOW
TDI -> HIGH
TMS -> HIGH
TDO -> LOW
nCE -> LOW
DURING JTAG SCAN:
nSTATUS -> HIGH
nCONFIG -> LOW
TCK -> Square wave with varying duty cycle
TDI -> Toggle few times (Some Bit stream)
TMS -> Toggles few times (Some Bit stream)
TDO -> LOW
Voltage Levels / Connections):
VCCINT: 1.2V
VCCIO : 3.3V (All VCCIOs)
VCCA : 2.5V
E-PAD : GND
JTAG Connector -PIN 4: 3.3V
nCONFIG : Pulled high by a 10K resistor (VCCIO)
nSTATUS : Pulled high by 10k resistor (VCCIO)
TCK : Pulled low by 1K
TDI : Pulled high by 10K (VCCA)
TMS: Pulled high by 10K (VCCA)
TDO : NO pull-up / down
nCE: GND
MSEL[2:0] : GND
According to Cyclone IV handbook the nCONFIG is an input pin but it looks like FPGA is driving it low after power ON, Why is that? Any ideas why JTAG chain scan failing on my board?
