11 years agoCyclone IV configuration - nCONFIG signal and JTAG programming issue
Hi, I have a custom board for EP4CE22E22 Cyclone IV FPGA. I have configured the board for JTAG only mode and using USB Blaster Rev.B for programming. The problem I am facing is that JTAG Scan f...
11 years agoThe rev B cable was updated to rev C to overcome this issue. The change was to move to a flex-rigid cable - the electronics in the USB-Blaster are unchanged.
So, you can get yourself a rev C cable and you'll be away. Alternatively, I suggest you shorten the ribbon cable on your rev B and you'll be happier, since won't have forked out for a new cable. I have several rev B cables all working happily with the new parts. See attached pic. Note - you don't need to go nearly as short as this! Cheers, Alex
