14 years agocyclone iii altlvds_tx and altlvds_rx?
i want to use altlvds_tx to transmit 16 bit data,so i set 2 channels,the deserialization factor is 8, ues externel pll. the data rate is 160Mpbs.
so the pll has two output clocks,c0 and c1, c0 is 80Mhz and c1 is 20Mhz. but i don't konw how to set the phase. then i link c0 to the tx_inclock,c1 to the syncclock,the altlvds_tx out put only have tx_out pin,so where is the clock output? if i want use altlvds_rx to receive, i set 2 channels,the deserialization factor is 8, ues externel pll,so it has port:rx_in,rx_inclock,and rx_out.so what is the frequency of the rx_inclock,i don't have the tx_outclock? so where is the rx_outclock? i am confuse with this problems. appreciate for all helps.2 Replies
Thanks! I get it!
Common sense suggests that the slow clock (frame clock) of 20 MHz must be transmitted along with the data to synchronize the receiver unequivocally. It can be output by altlvds_tx.
