14 years agocyclone iii altlvds_tx and altlvds_rx?
i want to use altlvds_tx to transmit 16 bit data,so i set 2 channels,the deserialization factor is 8, ues externel pll. the data rate is 160Mpbs. so the pll has two output clocks,c0 and c1, c0 is...
14 years agoCommon sense suggests that the slow clock (frame clock) of 20 MHz must be transmitted along with the data to synchronize the receiver unequivocally. It can be output by altlvds_tx.
