15 years agoCyclone 'EP1C3T100C8N' schematics
I have searched high and low and just cant find a simple schematic (bare minimum) to get this chip up and runnning.
Im just after how you wire it up with a JTAG interface and a simple boot prom. Any idea where i can find this? Thank you6 Replies
Ill make sure to upload my schematic once complete :) - Altera_Forum
--- Quote Start --- Just checked the schematic part, I cant beleave how simple these things are to setup :) --- Quote End --- Still, people do get it wrong ... as recent threads show. Here's few warnings; 1) Connection all VCCIO power banks, even if you do not use pins on those banks. 2) If the package has a power-pad (underneath it), make sure to connect it. 3) Connect all the device-specific programming pins appropriately, eg., nCE, MSEL[], nCONFIG, nSTATUS, CONF_DONE, (optional INIT_DONE), etc. 4) Connect the JTAG interface. Use a shrouded header for the PCB layout, as it helps to get the cable orientation correct. Make sure you leave enough room around the part. 5) Include a power-on-reset supervisor IC external to the FPGA. Its nice for producing a nice clean reset signal. You can usually connect a push-button input into the reset supervisor IC, and it'll debounce the signal for you. Look at other peoples designs, try to understand them. Cheers, Dave - Altera_Forum
Just checked the schematic part, I cant beleave how simple these things are to setup :) - Altera_Forum
--- Quote Start --- I see, iv attactched the schematic of the development board im using. but i would like to use a EP1C3T100C8N in my actual design not the EP2C5T144C8 So the JTAG and boot prom connections will be identical on the EP1C3T100C8N, its just a matter of using this chip and wiring it up the same as the EP2C5T144C8 Im a bit scared of forgetting to GND some special pin or having to have one held high --- Quote End --- The schematic looks fine. If I don't have a processor implementing the programming interface, then I like to put LEDs on signals, eg. the STATUS# signal will go low when there is a problem, so you can put a red LED on that and the CONF_DONE signal goes high when the FPGA is configured, so you can either use a red LED to indicate not configured, or a green LED to indicate its configured (I generally use a TinyLogic to drive LEDs; sink or source depending on when you want the LED on). Here's a reference schematic and some other docs: http://www.ovro.caltech.edu/~dwh/carma_board/ http://www.ovro.caltech.edu/~dwh/carma_board/gda06rb004_carma_rev_a.pdf Cheers, Dave - Altera_Forum
So the JTAG and boot prom connections will be identical on the EP1C3T100C8N, its just a matter of using this chip and wiring it up the same as the EP2C5T144C8 Im a bit scared of forgetting to GND some special pin or having to have one held high Thanks :) - Altera_Forum
--- Quote Start --- I have searched high and low and just cant find a simple schematic (bare minimum) to get this chip up and runnning. Im just after how you wire it up with a JTAG interface and a simple boot prom. Any idea where i can find this? --- Quote End --- Have you read the device handbook? http://www.altera.com/literature/lit-cyc.jsp Generally, you need to power up the core voltage and each of the I/O banks within a specified time, configure the JTAG interface with appropriate pull-ups or downs on the signals (so they do not float when the USB-Blaster is not present), and wire up the EEPROM. For example designs, just look at the schematics for a reference board. Don't worry if you cannot find an EP1C board, look for a Cyclone II or III, the JTAG and EEPROM interfaces have not changed. Cheers, Dave
