15 years agoCyclone 'EP1C3T100C8N' schematics
I have searched high and low and just cant find a simple schematic (bare minimum) to get this chip up and runnning. Im just after how you wire it up with a JTAG interface and a simple boot prom...
15 years ago --- Quote Start --- Just checked the schematic part, I cant beleave how simple these things are to setup :) --- Quote End --- Still, people do get it wrong ... as recent threads show. Here's few warnings; 1) Connection all VCCIO power banks, even if you do not use pins on those banks. 2) If the package has a power-pad (underneath it), make sure to connect it. 3) Connect all the device-specific programming pins appropriately, eg., nCE, MSEL[], nCONFIG, nSTATUS, CONF_DONE, (optional INIT_DONE), etc. 4) Connect the JTAG interface. Use a shrouded header for the PCB layout, as it helps to get the cable orientation correct. Make sure you leave enough room around the part. 5) Include a power-on-reset supervisor IC external to the FPGA. Its nice for producing a nice clean reset signal. You can usually connect a push-button input into the reset supervisor IC, and it'll debounce the signal for you. Look at other peoples designs, try to understand them. Cheers, Dave
