15 years agoCyclone 'EP1C3T100C8N' schematics
I have searched high and low and just cant find a simple schematic (bare minimum) to get this chip up and runnning. Im just after how you wire it up with a JTAG interface and a simple boot prom...
15 years ago --- Quote Start --- I see, iv attactched the schematic of the development board im using. but i would like to use a EP1C3T100C8N in my actual design not the EP2C5T144C8 So the JTAG and boot prom connections will be identical on the EP1C3T100C8N, its just a matter of using this chip and wiring it up the same as the EP2C5T144C8 Im a bit scared of forgetting to GND some special pin or having to have one held high --- Quote End --- The schematic looks fine. If I don't have a processor implementing the programming interface, then I like to put LEDs on signals, eg. the STATUS# signal will go low when there is a problem, so you can put a red LED on that and the CONF_DONE signal goes high when the FPGA is configured, so you can either use a red LED to indicate not configured, or a green LED to indicate its configured (I generally use a TinyLogic to drive LEDs; sink or source depending on when you want the LED on). Here's a reference schematic and some other docs: http://www.ovro.caltech.edu/~dwh/carma_board/ http://www.ovro.caltech.edu/~dwh/carma_board/gda06rb004_carma_rev_a.pdf Cheers, Dave
