AMaat's avatar
AMaat
7 years ago
Cyclone 5 SoC - HPS DDR - 16 Bit SDRAM on other bytelanes than 0 and 1
i'm currently designing a board with a Cyclone V SE with a single 16 bit DDR3 connected to Bytelanes 0 and 1.
in order to simplify the layout, the layouter requests to use other bytelanes instead. since i can't find any info on this in the datasheets i'm requesting it here.
For instance DQ0-7 on bytelane 1 and DQ8-15 on bytelane 4, is this supported in HW?
  • AMaat's avatar
    AMaat
    Hello Sir,
    thank you for your quick replies,
    Regards Arne
  • BoonT_Intel's avatar
    BoonT_Intel
    Yes, it should be ok as you can use any available DQ/DQS group (byte) from the FPGA to build your x16 interface.
    Anyway, as mentioned please try to fit it in Quartus. If quartus does not complaint then it is good to go. 😉
  • AMaat's avatar
    AMaat
    thanks for your reply,
    Currently DDR DQ0-7 nets ('bytelane 0') is referring to HPS_DQS_0 and HPS_DQS#_0 (Pins R17/R16) and DDR DQ8-15 nets ('bytelane 1')is referring to HPS_DQS_1 and HPS_DQS#_1 (Pins R19/R18)
    The layouter requests to connect DDR DQ0-7 nets ('bytelane 0') is referring to HPS_DQS_1 and HPS_DQS#_1 (Pins R19/R18) and and DDR DQ8-15 nets ('bytelane 1')is referring to HPS_DQS_4 and HPS_DQS#_4 (Pins V18/V17)
    i'll ask the quartus colleague to check this in the tooling
