16 years agocyclone 3 programming fail
hi
while i am programming cyclone3 in active serial configuration with usb blaster, following problem is coming 1.device chain in use 2.opeartion failed can any one help ..why this problem is coming regds mkraj4 Replies
Can you program a Cyclone III using active serial mode with a USB-Blaster? I thought you could only program serial configuration devices (EPCSx) using active serial mode.
Jake - Altera_Forum
Do you have any other application opened on the JTAG interface when you attempt to reprogram the FPGA? Such as a Nios console...
Do you put the FPGA to the "Program" module?
Can you paste the exact error which is coming?
