16 years agocyclone 3 programming fail
hi while i am programming cyclone3 in active serial configuration with usb blaster, following problem is coming 1.device chain in use 2.opeartion failed can any one help ..why this p...
16 years agoCan you program a Cyclone III using active serial mode with a USB-Blaster? I thought you could only program serial configuration devices (EPCSx) using active serial mode.
Jake
