Kodion22
1 year agoCyclone 3 Not entering AS Mode
Before i start, will love to say am new to FPGA and entry level with Electrical. We have an old tool we purchase that has a Cyclone 3 board on it. We have a simple code (attached) that we can easil...
sstrell
1 year agoIf you're not seeing the 30 or 40 MHz output on DCLK, maybe the device is damaged, causing a problem with the internal oscillator that drives DCLK. Is this a single board or happening on multiples?
Kodion22
1 year agoThanks for the swift response. I have manufactured 4 boards and the same thing. I have purchased multiple cyclone 3 chips and they all behave same way. Am able to connect via jtag with no issues but can never connect AS or if I load .pof code externally on the memory chip, it doesn't seem to be running. Also, the DCLK is not showing 30 to 40mhz.
Is the chip supposed to be showing that constant 30-40mhz on DCLK? If not, can any other external thing be a factor? Lime capacitor or resistors. I just don't understand the natural behavior of this FPGA
