cyclone 10GX - Programming issue
Here is the problem statement.
1. There are low pulses of ~1.7ms on the nStatus signal at every ~280ms interval. We suspect that this might be due to POR error.
- Power sequence is verified as per the guideline below in the handbook.
- There is delay of the 600ms between the last supply of the FPGA and the first supply of the IMX8.
- This delay is to restrict the IMX8 connections from creating any issue while FPGA is booting up.
2. JTAG chain is not being detected by the USB blaster.
- MSEL pins are configured as MSEL2:0 - 011 : AS + Standard POR delay
- When we configure MSEL pins to invalid combination (e.g. 111). JTAG is being detected. But flashing stops in between with an error saying "nConfig pin unable to get high level"
3. Active serial QSPI Flash is also connected to another processor in multi-master mode .
- We flashed .rpd in the AS flash but FPGA is not booting up.
my client shares documents with me that I cannot upload here, do you have an email to send the information?
- FakhrulA_altera
Hi ericmtzr,
As we have not heard from you for a while, this Case is idling. It is not recommended to idle for too long. Therefore following our support policy, I have to put this case in close status. My apologies if any inconvenience caused. Hence, This thread will be transitioned to community support.
If you have a new question, feel free to open a new thread to get support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
Fakhrul
- FakhrulA_altera
Hi ericmtzr,
I wish to follow up with you about this case. Do you have any updates?
Otherwise, this thread will be idling and marked as inactive, thus it will be transitioned to community support because there is no update received from you in a while.
Fakhrul
- FakhrulA_altera
Hi ericmtzr,
I wish to follow up with you about this forum case.
So do you still have any update on this?
Fakhrul
- FakhrulA_altera
Hi ericmtzr,
I noticed that the end customer mentioned that they're facing this issue on 6 boards out of 20 boards.
So, as to start troubleshooting and to narrow down the possible cause, have they tried to swap out the boards by substituting the 6 boards with a known-good device?
Fakhrul
- ericmtzr
Hello, let me check with the client and as soon as I have an answer I will confirm
- FakhrulA_altera
Hi ericmtzr,
We still looking into this issue. Will get to you once there is any findings.
Fakhrul
- Farabi_Altera
we will contact you through email. You can share the files there.
regards,
Farabi
