Cyclone 10 LP 10CL025 to 10CL006 migration
Thanks for answering ! I'm already sure that my QSF pin assignments is not an issue because I will not use the IO pins lost in 10CL006 U256 (These pins are connected to GND 1.2V or 2.5V with 10CL025) : I put all these pins in QSF as inputs with no weak pull-up.
I need "a confirmation that the 10CL006 FPGA will not have an abnormal behaviour with power voltage on these inputs located in the forbidden zone (between Vil and Vih) : as no FlipFlop (and consequently no CLK rising edge) are connected to these inputs, it should be OK ? No metastability or something else wrong ?"
Hi Zian,
Please refer to the pin connection guideline for the specific pins like pll/clock pins.
https://www.intel.com/content/www/us/en/docs/programmable/683137/current/clock-and-pll-pins.html
If it is a GPIO pins, it would be OK for leaving it without any pullup or pulldown.
But in general, we suggest to set it as tristate for the safety of circuit.
Ethan
