ESama's avatar
ESama
7 years ago
Cyclone 10 GX Transceiver PHY in PCS Direct vs Enhanced
Hello
I 'm working on an Intel Cyclone 10 GX developpement kit board with a native Transceiver PHY (Arria 10/cyclone 10) IP.
When I configure the transceiver in a "PCS Direct" mode every thing is OK but when I configure the same transceiver in a "Basic Enhanced mode" (without any other change) the transceiver doesn't work anymore: I get a static data at the TX serial line and also a static data at the RX receive port whatever the data sent to the RX serial line. Does any body have an idea?
Best regards
Etienne
  • Deshi_Intel's avatar
    Deshi_Intel
    Great ! Hopefully everything go well with the rest of your project development
  • ESama's avatar
    ESama
    The probleme is now solved: the pll_locked signal coming from the ATX PLL was not connected to the PHY Reset controller. Witout this pll_locked signal, the Transceiver was working well in a PCS direct mode but not in the PCS Enhanced mode.
    Thank you for your help
    Deshi_Intel
    HI Etienne,
    The tx_control register is used to tell whether current bit sent belongs to control bit or data bit.
    Anyway, looks like in your case, you can't send out data properly in your Tx channel and you also can't receive back expected data in your Rx channel.
    I would recommend to start with basic debug first like pls check FPGA power connection on board and also your transceiver design reset and clocking pins as per below pin connection guideline doc.
    Once you rule out there is no issue with your board then you can check at your Quartus design. Feel free to start with referring to some reference design to get something working first then you can slowly enable your desired setting in NativePHY IP. If it failed then you will know which setting is causing the issue.
    Your goal is to ensure you can send data correctly out from Tx channel first, after that you can move on to debug Rx channel.
    For Rx channel, check the CDR lock status first by looking at the cdr_lockedtodata pin. If it failed then you can refer to attached CDR debug guideline.
    Deshi
  • ESama's avatar
    ESama
    Hi dlim
    Thank you very much for your answer.
    At this stage, the reason why I want to use the Enhanced PCS (as compared to the Direct PCS) is the possibilty to have a fifo between pma and the fpga fabric. To do so, I choose the following options in the Transceiver PHY IP editor:
    • Transceiver configuration rules : Basic (Enhanced PCS)
    • Data rate : 5250
    • Enhanced PCS/PMA interface Width : 64
    • FPGA/FAbric/ Enhanced PCS interface Width : 64
    • TX FIFO Mode : Phase Compensation (for both tx and rx)
    All the other parameters of the Enhanced PCS are the default values given in the IP editor
    The data I get at the tx serial port (observed with a high speed oscilloscope) is always a continuous sequence of 111110001111100011111000.... whatever the data set at the parrallel port.
    The data I get at the rx parralel port is a constant.
    I set the tx_control register to 2'b01 but I not sure to understand the usefullness of that tx_control register. In any case whatever the value I have, I get the same pb.
    I don't use "dynamic reconfiguration".
    Thank you for your help !
    Best regards
    Etienne
    Deshi_Intel
    HI Etienne,
    When you use "PCS Direct" mode, you basically bypass most of the PCS block function.
    However when you enable "basic enhanced" mode, certain PCS block function is enabled depends on what PCS block and how you enable and configure them in NativePHY IP accordingly.
    Feel free to checkout below guideline to find out more about PCS block usage.
    https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/cyclone-10/ug_cyclone10_xcvr_phy.pdf
    dlim
