Cyclone 10 GX Transceiver PHY in PCS Direct vs Enhanced
Hi dlim
Thank you very much for your answer.
At this stage, the reason why I want to use the Enhanced PCS (as compared to the Direct PCS) is the possibilty to have a fifo between pma and the fpga fabric. To do so, I choose the following options in the Transceiver PHY IP editor:
- Transceiver configuration rules : Basic (Enhanced PCS)
- Data rate : 5250
- Enhanced PCS/PMA interface Width : 64
- FPGA/FAbric/ Enhanced PCS interface Width : 64
- TX FIFO Mode : Phase Compensation (for both tx and rx)
All the other parameters of the Enhanced PCS are the default values given in the IP editor
The data I get at the tx serial port (observed with a high speed oscilloscope) is always a continuous sequence of 111110001111100011111000.... whatever the data set at the parrallel port.
The data I get at the rx parralel port is a constant.
I set the tx_control register to 2'b01 but I not sure to understand the usefullness of that tx_control register. In any case whatever the value I have, I get the same pb.
I don't use "dynamic reconfiguration".
Thank you for your help !
Best regards
Etienne
