Custom linux image build failure for Arri10 SoC development kit
I am following the below documentation to build my custom Linux image for Arria10 SoC development kit. While building Yocto Rootfs, I am facing oe_runmake error. I have attached the log as well.
This is happening in the build process while compiling linux-socfpga-6.6+git package.
I tried below steps as well
step-1: bitbake -c cleanall linux-socfpga
step-2: bitbake linux-socfpga
But at step-2, again same issues.
Any help would be appreciated.
Sai
- tehjingy_Altera
Hi Sai
Are able to build the linux image without adding your custom recipe?
What are the error message that you get after adding custom recipe?
Jingyang, Teh
- sgannava
Hi Jingyang,
Sorry for late response.
I am able to build the dtb files after adding custom dts files. But I am facing bitbake errors while building rootfs using yocto, after adding custom recipes.
With Regards,
Sai
- tehjingy_Altera
Hi
Any update om this case?
Are you able successfully generate and run the generated GHRDbinaries?
Jingyang, Teh
- tehjingy_Altera
Hi
Thats great, that meanst he board is working properly.
Next step lets try the steps on generating the GSRD.
You could follow the steps below:
It is the steps to build to boot from SDCard like the GSRD.
Jingyang, Teh
- sgannava
Hi Jingyang,
The board is booting up with the pre-built linux binaries.
So, I can use pre-built .itb and uboot.img for initial booting and I can use .dtb and zimage files built by me for my application. Correct me if I am wrong.
Sai
- tehjingy_Altera
Hi Sai
Just to confirm you are working with the board below:
https://www.intel.com/content/www/us/en/products/details/fpga/development-kits/arria/10-sx.html
Instead of trying to build the binaries, could you try running the pre-built binaries to check the board is able to boot up?
https://www.rocketboards.org/foswiki/Documentation/Arria10SoCGSRD
Jingyang, Teh
- sgannava
Hi Jingyang,
Thanks for the response.
I am checking the GSRD image with the board I have. I will get back to you.
Sai
- sgannava
Hi Jingyang
I have tried only maiking changes in one level i.e. in linux.
I will try changing in both uboot and linux.
Apart from that, I have a general question. I have built the image without making any changes to dts, means I just reproduced the steps mentioned in rocketboards documentation. Image build was successful but I am not able to boot the board. There is nothing shown up in the bootlog
The board details I have are
Serial Number: 10ASXSoC003452 Rev C
Serial Number: 10ASXSoC003968
Sai
- tehjingy_Altera
Hi
Please find my response below:
1. Where can I include my custom device tree source files and re-build the image?
You could directly make changes to the device tree source file (socfpga_arria10_socdk_xxx.dts )in the repo that you have clone in your work directory. There are two level of device tree you will need to edit. One for the uboot and one for linux:
uboot
linux
/dts
2. Where can I make changes so that the image mounts to /mnt folder instead of /dev/mmcblk02
What do you mean the image mount point? Which image mount point are you referring to?
Are you referring to the linux image? The linux image needs to be from a dev eg. QSPI or sd card.
Jingyang, Teh
- sgannava
Hi Jingyang,
I am able to build the image successfully by removing the linux-socfpga_6.6bb (which is causing the error) blindly following the steps mentioned in the documentation. But I have below questions
Sai
- tehjingy_Altera
Hi
Are you following the steps from rocket board below?
Have you made changes to the original branch? Because by default the linux branch it is supposed to use is socfpga-6.1.68-lts
Jingyang, Teh
