shaneh_fl
1 year agoConverting Oscillator HCSL Output to SSTL_18
I am designing a PCB with a MAX 10 (10M50DAF256) with DDR2 and the MAX 10 requires a SSTL_18 clock source. I found Renesas AN-891 online and it describes using a HCSL driver, series 0.1uF capacitors ...
FvM
1 year agoHi,
thanks for referring to MAX10 FPGA Development Kit for clarification. I expect that respective capacitive coupling will also work for differential SSTL-18 clock input. According to my knowledge, differential clock input uses always the same differential input buffer. Actual common mode range is larger and minimal differential input voltage smaller than SSTL spec suggests. The clock input will most likely work driven by HCSL without capacitive coupling.
On the other hand, I don't see a purpose of having a separate clock source for DDR3 RAM IP. You'll preferably use an internal PLL source with defined phase relation to other design clock domains.
