Configuring Arria V Transceiver PLL for 2.5G Ethernet
I want to use the Multi-rate Ethernet IP at 2.5G on an Arria V device
The datasheet mentions that rx_clkout will be derived from tx_serial_clk:
And it seems like I’ll need to use a Transceiver PLL that operates at 1562.5 MHz.
How do I need to configure the Arria V Transceiver PLL to make it output a clock at 1562.5 MHz?
What PLL base data rate should be used ?
After checking on this, here's the connection guideline:
- The proper connections are to connect "fboutclk" to "pll_fbclk" and to leave "hclk" open.
Hope I've answered your query.
Regard,
Pavee
- paveetirrasrie_Altera
I’m glad that your question has been addressed, I now transition this thread to community support.
If you have a new question, feel free to open a new thread to get the support from Altera experts.
Thank you.
Pavee
Regard,
Pavee
Quartus will help on configuring PLL automatically.
Complete the following steps to configure a Transceiver PLL IP Core:
1. Under Tools > IP Catalog, select the device family of your choice.
2. Under Tools > IP Catalog > Interface Protocols > Transceiver PHY> Transceiver PLL .
3. Specify the options required for the PLL.
4. Click Finish to generate your parameterize Transceiver PLL IP Core.
Pavee
- host
That's exactly what I did:
And the PLL is generated as follows:
How should I connect the following ports ?
1. pll_fbclk (input)
2. fboutclk (output)
3. hclk (output)
- host
Thanks for the input.
I'm using only 2.5G so I need only one clock.
This is my Transceiver PLL component as generated by the IP wizard:
I have doubts about how to connect the following singals:
3. hclk (output)
Here's the connection required to operates PLL for 2.5G
Serial clock from transceiver PLLs.
• 2.5GbE: Connect bit [0] to the transceiver PLL. This clock operates at 1562.5 MHz
• 1GbE: Connect bit [1] to the transceiver PLL. This clock operates at 625 MHz.
• 10GbE: Connect bit [2] to the transceiver PLL. This clock operates at 5156.25 MHz.
Kindly refer to https://www.intel.com/content/www/us/en/docs/programmable/683171/current/clock-and-reset-signals.html for more detailed explanation.
Pavee
