host
1 year agoConfiguring Arria V Transceiver PLL for 2.5G Ethernet
Hello, I want to use the Multi-rate Ethernet IP at 2.5G on an Arria V device The datasheet mentions that rx_clkout will be derived from tx_serial_clk: And it seems like I’ll need to us...
- 1 year ago
After checking on this, here's the connection guideline:
- The proper connections are to connect "fboutclk" to "pll_fbclk" and to leave "hclk" open.
Hope I've answered your query.
Regard,
Pavee
host
1 year agoThanks for the input.
I'm using only 2.5G so I need only one clock.
This is my Transceiver PLL component as generated by the IP wizard:
I have doubts about how to connect the following singals:
1. pll_fbclk (input)
2. fboutclk (output)
3. hclk (output)
