14 years agoConfiguring ADC using FPGA
I am trying to configure an ADC using an FPGA. I can read the default values from the ADC register properly, but I'm unable to write to those registers. The fpga clock is 48 MHz and serial clock ...
14 years ago --- Quote Start --- Right, but its not working. So as a debugging aid, can you control the chip select signal? --- Quote End --- Yes I can control the chip select. I'll certainly give that a try, set CS high during power up and then set it low after a few clock cycles. What bothers me is I never fail to read the correct default value of a register. For now I have to change the address value in my VHDL code, re-compile the code, and re-program the FPGA. I would think a read would be more difficult to accomplish since the SDIO line has to change from an input to an output whereas for a write, it stays as an input line.
