JonGoh's avatar
JonGoh
1 year ago
Configuration via Protocol (CvP) fail after loading the periphery image
May I know if this issue has been resolved in newer versions of the CvP driver? I am still facing CvP intermittent failing problems and was wondering whether there are other workarounds other than the need for a power recycle.
"Due to a CvP upstream driver issue, CvP may intermittently fail after successfully loading the periphery image into all Intel Agilex® devices with package code R31C / R31B.".
Here is the link where I found the article:
https://www.intel.com/content/www/us/en/support/programmable/articles/000089044.html
Jon
  • JohnT_Altera's avatar
    JohnT_Altera
    From the log file, you are running in PCIe Gen3x8. Is this the design loaded into the FPGA?
    JohnT_Altera
    Please copy the "lspci -vv" and "uname -mrs" printout of the FPGA board. Please also provide the step you use to update the kernel.
    • JonGoh's avatar
      JonGoh
      Hi @JohnT_Intel ,
      01:00.0 Unassigned class [ff00]: Altera Corporation Device 09c4 (rev 01)
      Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
      Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
      Region 0: Memory at f0000000 (64-bit, prefetchable) [disabled] [size=4M]
      Region 4: Memory at f0400000 (64-bit, prefetchable) [disabled] [size=256K]
      Capabilities: [40] Power Management version 3
      Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold-)
      Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
      Capabilities: [70] Express (v2) Endpoint, MSI 00
      DevCap: MaxPayload 512 bytes, PhantFunc 0, Latency L0s <64ns, L1 <1us
      ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 75.000W
      DevCtl: CorrErr+ NonFatalErr+ FatalErr+ UnsupReq+
      RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop+ FLReset-
      MaxPayload 256 bytes, MaxReadReq 512 bytes
      DevSta: CorrErr+ NonFatalErr- FatalErr- UnsupReq+ AuxPwr- TransPend-
      LnkCap: Port #1, Speed 8GT/s, Width x8, ASPM not supported
      ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp+
      LnkCtl: ASPM Disabled; RCB 64 bytes, Disabled- CommClk+
      ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
      LnkSta: Speed 8GT/s (ok), Width x8 (ok)
      TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
      DevCap2: Completion Timeout: Range ABCD, TimeoutDis+ NROPrPrP- LTR+
      10BitTagComp+ 10BitTagReq+ OBFF Not Supported, ExtFmt+ EETLPPrefix+, MaxEETLPPrefixes 1
      EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
      FRS- TPHComp+ ExtTPHComp-
      AtomicOpsCap: 32bit+ 64bit+ 128bitCAS+
      DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis- LTR+ OBFF Disabled,
      AtomicOpsCtl: ReqEn-
      LnkCap2: Supported Link Speeds: 2.5-8GT/s, Crosslink- Retimer+ 2Retimers+ DRS-
      LnkCtl2: Target Link Speed: 8GT/s, EnterCompliance- SpeedDis-
      Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
      Compliance De-emphasis: -6dB
      LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete+ EqualizationPhase1+
      EqualizationPhase2+ EqualizationPhase3+ LinkEqualizationRequest-
      Retimer- 2Retimers- CrosslinkRes: Upstream Port
      Capabilities: [b0] MSI-X: Enable- Count=16 Masked-
      Vector table: BAR=0 offset=00100000
      PBA: BAR=0 offset=00180000
      Capabilities: [100 v2] Advanced Error Reporting
      UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
      UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
      UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
      CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr-
      CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr+
      AERCap: First Error Pointer: 00, ECRCGenCap+ ECRCGenEn- ECRCChkCap+ ECRCChkEn-
      MultHdrRecCap- MultHdrRecEn- TLPPfxPres- HdrLogCap-
      HeaderLog: 00000000 00000000 00000000 00000000
      Capabilities: [148 v1] Virtual Channel
      Caps: LPEVC=0 RefClk=100ns PATEntryBits=1
      Arb: Fixed- WRR32- WRR64- WRR128-
      Ctrl: ArbSelect=Fixed
      Status: InProgress-
      VC0: Caps: PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
      Arb: Fixed- WRR32- WRR64- WRR128- TWRR128- WRR256-
      Ctrl: Enable+ ID=0 ArbSelect=Fixed TC/VC=ff
      Status: NegoPending- InProgress-
      Capabilities: [174 v1] Alternative Routing-ID Interpretation (ARI)
      ARICap: MFVC- ACS-, Next Function: 1
      ARICtl: MFVC- ACS-, Function Group: 0
      Capabilities: [184 v1] Secondary PCI Express
      LnkCtl3: LnkEquIntrruptEn- PerformEqu-
      LaneErrStat: 0
      Capabilities: [46c v1] Data Link Feature <?>
      Capabilities: [d00 v1] Vendor Specific Information: ID=1172 Rev=0 Len=05c <?>
      apd@apd-pc1:~$ uname -mrs
      Linux 6.6.37+ x86_64
      Steps that I took to update the kernel (following the guide that you mentioned above):
      git clone https://github.com/altera-opensource/linux-socfpga
      cd linux-socfpga
      git checkout socfpga-6.6.37-lts
      cd /usr/src/linux-socfpga
      cp -v /boot/config-$(uname -r) .config
      make menuconfig
      - Set Altera CvP FPGA Manager and FPGA Manager DebugFS to *
      Make -j 12
      export INSTALL_MOD_PATH=/usr/src/linux-socfpga
      MODPATH="INSTALL_MOD_PATH=/usr/src/linux-socfpga"
      ARGS="$MODPATH"
      make $ARGS modules
      sudo make modules_install
      sudo make install
      grub-mkconfig
      cat /boot/grub/grub.cfg
      sudo cp /etc/default/grub /etc/default/grub.bak
      cat /etc/default/grub
      gedit/etc/default/grub
      sudo update-grub
      Hope this gives more insight to the problem.
      Jon
    JohnT_Altera
    Can you share with the the log file so that we can further look into the issue?
    • JonGoh's avatar
      JonGoh
      Hi @JohnT_Intel ,
      How do I generate the log file? Or where can I locate the log file?
      Jon
    • JonGoh's avatar
      JonGoh
      Hi @JohnT_Intel ,
      Yes I have done git checkout 6.6.37-lts, built the kernel and verified that it is "Linux 6.6.37+ x86_64". I have also ensured that these are selected:
      • CONFIG_FPGA=y
      • CONFIG_FPGA_MGR_DEBUG_FS=y
      • CONFIG_FPGA_MGR_ALTERA_CVP=y
      I also noticed that fpga_manager directory does not exist at "/sys/kernel/debug". Do you have any idea what could be the problem?
      Jon
    • JonGoh's avatar
      JonGoh
      Hi @JohnT_Intel ,
      I have changed to 6.6.37-lts version. However, it seems like the driver is not loaded properly. After entering lspci -vvv -d1172:, I do not see the output "Kernel driver in use: altera-cvp", and I can't upload my core image either. Is there a difference in the procedure for version 6.6.37-lts? And where else can I look to troubleshoot this issue?
      Jon
  • JonGoh's avatar
    JonGoh
    Hi @JohnT_Intel ,
    I am using Quartus 24.2 and Linux kernel version 5.15.30, and I am following the Agilex 7 Device Configuration via Protocol (CvP) Implementation User Guide that is available. What are some areas that I can look into to try resolve the issue?
    Jon
    JohnT_Altera
    The issue has been fixed in Quartus 22.2. May I know which version are you using that you are still observing the issue?
