JonGoh
1 year agoConfiguration via Protocol (CvP) fail after loading the periphery image
Hi, May I know if this issue has been resolved in newer versions of the CvP driver? I am still facing CvP intermittent failing problems and was wondering whether there are other workarounds other th...
JohnT_Altera
1 year agoHi,
After you getting the new source code, have you rebuild the code?
Below is the guide to build the driver.
Please help to run "uname -mrs" to see which kernel you are using.
JonGoh
1 year agoHi @JohnT_Intel ,
Yes I have done git checkout 6.6.37-lts, built the kernel and verified that it is "Linux 6.6.37+ x86_64". I have also ensured that these are selected:
- CONFIG_FPGA=y
- CONFIG_FPGA_MGR_DEBUG_FS=y
- CONFIG_FPGA_MGR_ALTERA_CVP=y
I also noticed that fpga_manager directory does not exist at "/sys/kernel/debug". Do you have any idea what could be the problem?
Jon
