Configuration via Protocol (CvP) fail after loading the periphery image
Please copy the "lspci -vv" and "uname -mrs" printout of the FPGA board. Please also provide the step you use to update the kernel.
- JonGoh1 year ago
Hi @JohnT_Intel ,
01:00.0 Unassigned class [ff00]: Altera Corporation Device 09c4 (rev 01)Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-Region 0: Memory at f0000000 (64-bit, prefetchable) [disabled] [size=4M]Region 4: Memory at f0400000 (64-bit, prefetchable) [disabled] [size=256K]Capabilities: [40] Power Management version 3Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold-)Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-Capabilities: [70] Express (v2) Endpoint, MSI 00DevCap: MaxPayload 512 bytes, PhantFunc 0, Latency L0s <64ns, L1 <1usExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 75.000WDevCtl: CorrErr+ NonFatalErr+ FatalErr+ UnsupReq+RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop+ FLReset-MaxPayload 256 bytes, MaxReadReq 512 bytesDevSta: CorrErr+ NonFatalErr- FatalErr- UnsupReq+ AuxPwr- TransPend-LnkCap: Port #1, Speed 8GT/s, Width x8, ASPM not supportedClockPM- Surprise- LLActRep- BwNot- ASPMOptComp+LnkCtl: ASPM Disabled; RCB 64 bytes, Disabled- CommClk+ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-LnkSta: Speed 8GT/s (ok), Width x8 (ok)TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-DevCap2: Completion Timeout: Range ABCD, TimeoutDis+ NROPrPrP- LTR+10BitTagComp+ 10BitTagReq+ OBFF Not Supported, ExtFmt+ EETLPPrefix+, MaxEETLPPrefixes 1EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-FRS- TPHComp+ ExtTPHComp-AtomicOpsCap: 32bit+ 64bit+ 128bitCAS+DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis- LTR+ OBFF Disabled,AtomicOpsCtl: ReqEn-LnkCap2: Supported Link Speeds: 2.5-8GT/s, Crosslink- Retimer+ 2Retimers+ DRS-LnkCtl2: Target Link Speed: 8GT/s, EnterCompliance- SpeedDis-Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-Compliance De-emphasis: -6dBLnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete+ EqualizationPhase1+EqualizationPhase2+ EqualizationPhase3+ LinkEqualizationRequest-Retimer- 2Retimers- CrosslinkRes: Upstream PortCapabilities: [b0] MSI-X: Enable- Count=16 Masked-Vector table: BAR=0 offset=00100000PBA: BAR=0 offset=00180000Capabilities: [100 v2] Advanced Error ReportingUESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr-CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr+AERCap: First Error Pointer: 00, ECRCGenCap+ ECRCGenEn- ECRCChkCap+ ECRCChkEn-MultHdrRecCap- MultHdrRecEn- TLPPfxPres- HdrLogCap-HeaderLog: 00000000 00000000 00000000 00000000Capabilities: [148 v1] Virtual ChannelCaps: LPEVC=0 RefClk=100ns PATEntryBits=1Arb: Fixed- WRR32- WRR64- WRR128-Ctrl: ArbSelect=FixedStatus: InProgress-VC0: Caps: PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-Arb: Fixed- WRR32- WRR64- WRR128- TWRR128- WRR256-Ctrl: Enable+ ID=0 ArbSelect=Fixed TC/VC=ffStatus: NegoPending- InProgress-Capabilities: [174 v1] Alternative Routing-ID Interpretation (ARI)ARICap: MFVC- ACS-, Next Function: 1ARICtl: MFVC- ACS-, Function Group: 0Capabilities: [184 v1] Secondary PCI ExpressLnkCtl3: LnkEquIntrruptEn- PerformEqu-LaneErrStat: 0Capabilities: [46c v1] Data Link Feature <?>Capabilities: [d00 v1] Vendor Specific Information: ID=1172 Rev=0 Len=05c <?>apd@apd-pc1:~$ uname -mrs
Linux 6.6.37+ x86_64Steps that I took to update the kernel (following the guide that you mentioned above):
git clone https://github.com/altera-opensource/linux-socfpga
cd linux-socfpga
git checkout socfpga-6.6.37-lts
cd /usr/src/linux-socfpga
cp -v /boot/config-$(uname -r) .config
make menuconfig
- Set Altera CvP FPGA Manager and FPGA Manager DebugFS to *
Make -j 12
export INSTALL_MOD_PATH=/usr/src/linux-socfpga
MODPATH="INSTALL_MOD_PATH=/usr/src/linux-socfpga"
ARGS="$MODPATH"
make $ARGS modules
sudo make modules_install
sudo make install
grub-mkconfig
cat /boot/grub/grub.cfg
sudo cp /etc/default/grub /etc/default/grub.bak
cat /etc/default/grub
gedit/etc/default/grub
sudo update-grub
Hope this gives more insight to the problem.
Jon
