10 years ago[Configuration Related] Cyclone III AP Configuration
Dear Host,
I am designing Cyclone III EP3C120 Board. On this board, i am configuring FPGA with AP configuration. In this configuration, i am using Micron P33 Parallel NOR Flash Memory.I will program the configuration through JTAG interfacing. For VCCIO banks 1,6,7 and 8, i will use 3.3V. Please provide additional information, if necessary. Regards, Mohsin Hayat12 Replies
One More Point,sir that i want to discuss wid u regarding FPP Configuration, please refer to the document, "Parallel Flash Loader IP CORE User Guide". In this document, at the page 10, this describe the CFI Flash with CPLD only.I am confuse on this point.Please clear it.
Yes - With Cyclone III, if you configure using AS from a serial FLASH device, you can then access/use that same FLASH device to boot Nios or simply access it from your Nios code.
Cheers, Alex
