10 years ago[Configuration Related] Cyclone III AP Configuration
Dear Host, I am designing Cyclone III EP3C120 Board. On this board, i am configuring FPGA with AP configuration. In this configuration, i am using Micron P33 Parallel NOR Flash Memory.I will progr...
10 years agoYes - With Cyclone III, if you configure using AS from a serial FLASH device, you can then access/use that same FLASH device to boot Nios or simply access it from your Nios code.
Cheers, Alex
