SLeit's avatar
SLeit
6 years ago
Configuration problem under low temperature at 10M04SAE144I7G
the Configuration work well at room temperature
when we goes down to 10 Celsius degree and down to - 20 Celsius and turn on the board voltage the device no get the configuration
  • YuanLi_S_Intel's avatar
    YuanLi_S_Intel
    Hi Shraga,
    I am sorry, those configuration pin are needed for configuration purposes. We cannot disable them.
    So, is this function work?
    YL
  • SLeit's avatar
    SLeit
    Dear YL.
    it is very strange
    when we are load a POF file it is loaded at low temperature but not working
    when we load a SOF file it is loaded and working
    can you explain this problem ?
    Sharag
  • SLeit's avatar
    SLeit
    dear YL
    it is very strange.
    when we load a POF file at low temperature it is loaded but not working
    when we load a SOF file at low temperature it is loaded and working
    can you explain ?
    thank you in advance
    Shraga
    YuanLi_S_Intel
    Hi Shraga,
    This is weird. Can you try to recompile the bitstream and try again?
    YL
  • MSalvot's avatar
    MSalvot
    Hi there,
    We experienced the exact same problem here on ~20 components 10M16SCU169A7G.
    MAX10 do not configure from the integrated flash when temperature drop bellow ~15°C.
    We shall power cycle the MAX10 until it get configured and respond to our system at start-up.
    When it get configured, we can hard freeze it, he still works as intended.
    Does Intel/Altera has investigated the issue ?
    BR,
    Marc.
  • MSalvot's avatar
    MSalvot
    More precisely, it looks like the configuration delay increase a lot when the device is cold.
    It can take several minutes before MAX10 answer to the communication bus (~15 min worst case we had).
    Power cycling it seems to make configuration longer, like if the configuration started from scratch at the same incredibly low speed.
    Integrated in the global system, with timeouts and auto power cycle, made debugging quite confusing…
