16 years agocode style for mixed width port dpram
hi,everybody.How to modify this code to generate a mixed width port dpram,
the simplest example such as : emodule true_dpram_sclk ( input [7:0] addr_a, input [0:0] data_a, input [4:0] addr_b, input [7:0] data_b, input we_a, clk, output reg q_a, output reg [7:0] q_b ); // Declare the RAM variable reg [0:0] ram[63:0]; // Port A always @ (posedge clk) begin if (we_a) begin ram[addr_a] <= data_a; q_a <= data_a; end else begin q_a <= ram[addr_a]; end end // Port B always @ (posedge clk) begin q_b[0] <= ram[{addr_b,3'd0]; q_b[1] <= ram[{addr_b,3'd1]; q_b[2] <= ram[{addr_b,3'd2]; q_b[3] <= ram[{addr_b,3'd3]; q_b[4] <= ram[{addr_b,3'd4]; q_b[5] <= ram[{addr_b,3'd5]; q_b[5] <= ram[{addr_b,3'd6]; q_b[7] <= ram[{addr_b,3'd7]; end endmodule /////////////////// This code works ok,but it get more alms and other resources in ep2sxx . When i used Megawizard to generate the same funciton LPM,and it just waste one m4ks. Now the situations is i can't used the LPM code,how can i changer my verilog code style get the the same result of LPM. Please help.thanks a lot! The reference code is : emodule true_dpram_sclk ( input [7:0] data_a, data_b, input [5:0] addr_a, addr_b, input we_a, we_b, clk, output reg [7:0] q_a, q_b ); // Declare the RAM variable reg [7:0] ram[63:0]; // Port A always @ (posedge clk) begin if (we_a) begin ram[addr_a] <= data_a; q_a <= data_a; end else begin q_a <= ram[addr_a]; end end // Port B always @ (posedge clk) begin if (we_b) begin ram[addr_b] <= data_b; q_b <= data_b; end else begin q_b <= ram[addr_b]; end end endmodule3 Replies
in this case it should be submitted to Altera as a synthesis enhancement.
Please use direct instantiation instead of inferrence.
AFAIK is the only way to achieve mixed width port dpram - Altera_Forum
Hunger for your answer!haha.................That sounds really upset,right?What about the altera FAE?Have they seen that?
