17 years ago
code problem
Hi, I am wring a mermory code, but the waveform is not correct. There is no change of fin_add, only when add_en='1' then add_en_next change. I think probable it is coz the used(num) never become zero. but I don't know this happen. my code is as folllow:
architecture behv of mry is
signal num,match_num:integer;
signal used:std_logic_vector(3 downto 0);--!
type CAM is array(0 to 3) of std_logic_vector(15 downto 0);
signal data_array: CAM;
begin
process (init,add_en,num,used)
begin
fin_init<='0';
fin_add<='0';
add_en_next<='0';
if init='1' then --init
used<=(others=>'0');
fin_init<='1';
elsif add_en='1' then ---add
for num in 0 to 3 loop
add_en_next<='1';
if used(num)='0' then ---cell is empty
add_en_next<='0';
used(num)<='1';
data_array(num)(15 downto 8)<=H_Dn;
data_array(num)(7 downto 0)<=H_GD;
fin_add<='1';
exit;
end if;
end loop;
end if;
end process;
end behv;
