17 years agocode problem
Hi, I am wring a mermory code, but the waveform is not correct. There is no change of fin_add, only when add_en='1' then add_en_next change. I think probable it is coz the used(num) never become zero...
17 years agocaraey,
If to tell why your code is not working, that's because you assign: fin_add<='0'; and fin_add<='1'; in the same process. Only the last assignment to a signal is in force. Read more about VHDL: Behavior with Processes
