17 years agocode problem
Hi, I am wring a mermory code, but the waveform is not correct. There is no change of fin_add, only when add_en='1' then add_en_next change. I think probable it is coz the used(num) never become zero...
17 years agoI was just describing the situation why the "fin_add" never changes. At the beginning there is the code
--- Quote Start --- process (init,add_en,num,used) begin fin_init<='0'; fin_add<='0'; --- Quote End --- and logically there should be a change of the fin_add after something changed in the sensivity list. But since the process exectution enters the IF branch - fin_add<='1' and only last assignment in the process takes place. Therefore he will not notice '0' assignment on the waveform. Thats true If his fin_add always = '1' this means that his process always enters to the branch there fin_add assigned '1'. The problem can be in the testbench.
