3LionsCT's avatar
3LionsCT
6 months ago
Change the default USB Blaster II Hardware Frequency?
My USB blaster will not work at the default hardware frequency of 24MHz but works fine at 16MHz.  I have to change it every time in the programmer or when using Signal tap. Is there a parameter within Quartus that will make it default to 16MHz rather than 24MHz.
  • FvM's avatar
    FvM
    apparently there's no feature to store a frequency setting permanently. Interestingly Arrow-USB-Blaster stores the default in Registry. Actual frequency can be modified with jtagconfig --setparam, but it's reset to default when cable is plugged in oder Jtagserver restarted. You also need to know the cable number if you have more than one cable attached.
    "jtagconfig --setparam 1 JtagClock 16M" could be e.g. called in post compilation flow as a workaround.
    Frank
    • 3LionsCT's avatar
      3LionsCT
      Hi Frank,
      That's what I figured. I saw the command line instruction but at that point its just easier to change it in the programming GUI
      Sees like a feature that would be good to add to Quartus in the future!
      • Farabi_Altera's avatar
        Farabi_Altera
        I will file CR (feature request) to engineering for future improvement.
        regards,
        Farabi
