Can't compile example Cyclone10 GX projects in Quartus Prime 23.1 Pro
To get off the ground with my shiny, new (and expensive) Cyclone 10 GX development board I went to https://www.intel.com/content/www/us/en/design-example/714945/cyclone-10-gx-pcie-gen2-x4-dma.html and downloaded the .par file. Quartus 23.1 was happy to open it and wanted to run an IP upgrade, which also ran.
However, compiling falls over with the error:
Error(19021): The same file name "top_hw" is used for different IP files. The same name cannot be used for more than one IP file. Only directly include the .ip file, not the .qip or .qsys.
Error(22175): file: "C:/Users/olivers/Documents/sbsvn/Client/misc/GXexamples/Cyclone10GX_PCIeGen2x4_DMA_18_0_project/platform/top_hw.qsys"
Error(22175): file: "C:/Users/olivers/Documents/sbsvn/Client/misc/GXexamples/Cyclone10GX_PCIeGen2x4_DMA_18_0_project/platform/top_hw/top_hw.qip"
If I remove the QIP then compilation crashes the Quartus fitter.
Any suggestions?
Hi Oliver,
I don't see any report. However I am recalling a known issue, do you receive the same Internal Error: Internal Error: Sub-system: DCALC, File: /quartus/ddb/dcalc/dcalc_bcm_modules_cache.cpp, Line: 176Could not load pdb file - e:/quartus/quartusprimepro23.1_installed/devices/20nm/ddb_nightfury_timing_corner_db
Do you have only Cyclone 10 GX device installed? If yes, the current workaround in 23.1 is to install Arria 10 device, or you may use 22.4 instead.
Nurina
- sstrell
Go into Platform Designer, opening the .qsys file, and try generating the system manually there. Then try compiling again in Quartus.
- Oliver_I_Sedlacek
Contributor
Aaargh, another miserable morning trying to log in! Anyway I tried manual QSYS generation and it made no difference, Quartus still crashed.
- Oliver_I_Sedlacek
Contributor
See above, no difference. I do submit crash reports but there's no sign that Intel receive them.
