Can't compile example Cyclone10 GX projects in Quartus Prime 23.1 Pro
- 3 years ago
Hi Oliver,
I don't see any report. However I am recalling a known issue, do you receive the same Internal Error: Internal Error: Sub-system: DCALC, File: /quartus/ddb/dcalc/dcalc_bcm_modules_cache.cpp, Line: 176Could not load pdb file - e:/quartus/quartusprimepro23.1_installed/devices/20nm/ddb_nightfury_timing_corner_db
Do you have only Cyclone 10 GX device installed? If yes, the current workaround in 23.1 is to install Arria 10 device, or you may use 22.4 instead.
Nurina
Hi Oliver,
Nurina
- Oliver_I_Sedlacek3 years ago
Contributor
Nurina, thanks for that, yes adding Arria 10 device support fixes the Quartus crashing problem. We had a public holiday here on Monday, and with the time zone difference you'll have to cut me some slack on getting back to you.
Oliver
