Can't compile example Cyclone10 GX projects in Quartus Prime 23.1 Pro
- 3 years ago
Hi Oliver,
I don't see any report. However I am recalling a known issue, do you receive the same Internal Error: Internal Error: Sub-system: DCALC, File: /quartus/ddb/dcalc/dcalc_bcm_modules_cache.cpp, Line: 176Could not load pdb file - e:/quartus/quartusprimepro23.1_installed/devices/20nm/ddb_nightfury_timing_corner_db
Do you have only Cyclone 10 GX device installed? If yes, the current workaround in 23.1 is to install Arria 10 device, or you may use 22.4 instead.
Nurina
Go into Platform Designer, opening the .qsys file, and try generating the system manually there. Then try compiling again in Quartus.
Aaargh, another miserable morning trying to log in! Anyway I tried manual QSYS generation and it made no difference, Quartus still crashed.
- Oliver_I_Sedlacek3 years ago
Contributor
See above, no difference. I do submit crash reports but there's no sign that Intel receive them.
