16 years ago
Can't build project in the NIOS II IDE
--- Quote Start ---
--- Quote Start ---
--- Quote Start ---
i have a DE1 board with Cyclone II EP2C20.. device. I designed my hardware and add all the required components in the SOPC Builder. I use now On-Chip-Memory (later i will use flash for programming). I created new software project in the NIOS II IDE and so on, but i got following error message when i try to build the project in the NIOS II IDE.
"ld: region onchip_memory2_0 is full (Loto_Generator.elf section .text). Region needs to be 35120 bytes larger. Loto_Generator line 0 1259878959171 305
ld: section .bss [00006004 -> 00006223] overlaps section .text [000041c8 -> 0000f9cb] Loto_Generator line 0 1259881350484 337
ld: section .rodata [00004020 -> 000045c7] overlaps section .exceptions [00004020 -> 000041c7] Loto_Generator line 0 1259881350484 335
ld: section .rwdata [000045c8 -> 00006003] overlaps section .text [000041c8 -> 0000f9cb] Loto_Generator line 0 1259881350484 336"
The problem is that i can't use to much size of On-Chip-Memory because my design uses then to much M4K blocks and it doesn't pass the compilation process in the Fitter.
Can anyone please help me? I know i could use SRAM memory instead On-Chip, but is there another option?
Thanks in advance!
    When you use out_memory ,in program you should use main() function not alt_main() function !Do you use it correctly?
    Yes i set it. I removed the on-chip memory and use now SRAM, but i got problem when i build the project.
    Severity and Description Path Resource Location Creation Time Id
    /cygdrive/s/altera/nios2eds/components/altera_hal/HAL/src/alt_main.c undefined reference to `main' Loto_Generator line 165 1260018831078 2
    Have any advise what should i do to remove it?
    Friends, do you set library proprety for example smallC library?
    if your setting is ok,I think you must use SRAM or Sdram in board!
