16 years agoCan't build project in the NIOS II IDE
--- Quote Start --- --- Quote Start --- --- Quote Start --- Hi, i have a DE1 board with Cyclone II EP2C20.. device. I designed my hardware and add all the required components ...
16 years agoFriends, do you set library proprety for example smallC library?
if your setting is ok,I think you must use SRAM or Sdram in board!
